Clio 16v / Clio Williams
ok heres the problem, car was running fine, started it one day sat waiting outside a shop for a mate, it cuts out, no stuttering or sign of fuel starvation, just dead, wouldnt start again, checked and it wasnt firing
replaced, plugs, dizzy, rotor arm, crank angle sensor and coil. didnt get leads cos i needed the car that day and they couldnt get them in, anyway, did all this and it ran again, been ok for a week, done near 500 miles since, then today, the same thing happens again...
gonna change the leads tomorrow as they are the last thing i havent changed, even though they look fine, but if this doesnt sort it, any ideas? its a valver, but with a willy engine, which i dropped in a month or so ago now. 1992 k reg, engine is from an m reg willy. car doesnt have an imobiliser or trick alarm, just standard stuff.
The only bit i havent replaced, apart from the leads, is the amplifier, as in the bit behind the coil, which i suspect could be dodgy cos my rev meter doesnt work, but that never has...its really pissing me off because i need my car to get to work and what not.
if anyone can help that would be much appreciated,
Thanks, Tobe.
Thanks, Tobe.
