steering rack play
  White Evo V
I have just removed my airbag as I thought that the torx bolt in the middle of the steering wheel had come loose, when I eventually got it off I noticed that the play is in the actual steering rack that the wheel bolts onto! It moves about 2mm each way - not good! :(
Any suggestions?
  Fabia vrs tdi
My wheel moves slightly up and down and when turning left or right it sounds like its clickin or catching on somethin, do you suggest taking wheel off to see if my bolt has came loose or could it be the rack too?
Racks second hand are £35 quid. I have one spare actually if you were nearer, bought off Joshydee and Cliospares but realised my issue was badly done tracking and alignment.
In fact, Ben, you are close, fitment is usually about 100 quid, so if you want this one (based just below Manc) it's yours. No use to me since I've sold the car.
  Fabia vrs tdi
When i got my tyres replaced the sides were bald it needs tracking done but sure that wouldnt give play in steering wheel up and down.
  Fabia vrs tdi
Yeah but i said in the thread i started it sounds as if its clicking and catching on somethin it could be a couple of things and dont wanna put it into garage and the screw me
