I looking more to would a 2002 Clio boss fit a 2002 V6 steering column.
I can't see why it shouldn't, spoken to a few suppliers but no one gives a definitive answer if the boss is V6 specific or if a 2002 Clio one would fit.
If you look down the list you'll see the same boss kit listed for quite a few clios. Mk 2's and mk 3's. Theres a good chance the omp ones will be listed the same.
Renault have alot of carry over parts on they're cars.
Tbh if the steering wheel for a ph 1 172 is the same as the ph 1 v6 there's your answer.
I worked out for mine that the 197 steering wheel is a straight swap on the megane 225s, so with that in mind a 197 boss kit must fit as the splines will be the same and sure enough I was correct.
If you apply the same methodology to yours then it should be easy enough to work backwards.
If you can avoid it don't get one from demon tweeks as they ballsed mine right up. Listed a momo one that would fit when in fact momo don't even make one for the megane 225!!
Alot of people use jjc race and rally, I did. Yb racing too are good I've heard.
