Sticky throttle? - any ideas
Car  RenaultSport clio 172 mk1
Been having a little problem
Driving around town. Once the car is warmed up. Normal driving, then when you approach a set of lights (stop etc) and then put in the clutch ro roll to a stop, the engine is still ticking over at 2000 rpm, blip the throttle and then it drop to a normal idle, well until the next stop. Only happens when the car is warmed up???
A common problem??? any ideas to what it is or what i need to do to sort it???
it will be your throttle cable sticking mate,common problem, buy a new cable, pm me and il send you firring instructions if that helps
