Still missfire 6019 and 6029....
  Clio 182
So I have changed plugs coil pack leads and all 4 injectors timing has been checked and it fine had compression test done fine......
Still bringing codes 6019 and 6029 I'm guessing its misfiring on 2 cylinders? Bit doesn't tell me which ones..... please help
  182 clio
Does your code reader not tell you what fault code means?
Can you unplug the leads one by one and see which makes no difference to the poor running (and therefore which cylinders aren't running right)?
Could you swap the coil packs round to see if it makes a difference?
  Clio 182
Checked efi loom fine I will take off and check individual lead for which one..... the light flashes for couple off mins then goes off and comes back on next time I start car then after a few mins again goes off
  Clio 182
Yeah Renault number and iwp042 on side.... but on second view 3 off the injectors are actually long than 1? What that all about they haven't changed them have they?
  Clio 182
Yeah well its number 3 which is the only original injector left the supplier Is gunna send me another one free of charge and swears they are original hopefully that fixes the problem.... 1 injector being shorter is diffinatly gonna cause an issue.... but it's not leaking fuel which is wierd
