Can any body offer any advice at all about this piece of s**t car of mine?
182
Just replaced the clutch, everything works as it should, I can get all the gears, clutch presses and depresses as normal, crank moves freely, compression seems fine, gearbox moves as normal
Car just won't turn over/fire
Really starting to lose my temper with the f**king thing
Checked all 3 earth points as it was suggested there was an issue there, cleaned them all up and put them back, everything is plugged in, dash lights up as normal but when you turn the key to start it the starter just goes *clunk*
Even had the starter motor of and checked that and when you supply power, and earth and signal it turns
Run out of ideas, worked fine before I took it apart, I have had it apart 3-4 times and checked everything I can, all plugs connected, all bolts tight, all fluids full with fresh fluids
Even put a jump lead cable between engine and negative on the battery to earth it that way, same with gearbox and same thing
Only thing I can think of is a break in the loom wiring? But I really don't wanna piss about replacing that...
Any ideas or anything else I can check?
182
