stop light and handbrake light
Car  Clio 1.6 16v 2002
when im driving around at the moment ...well for like the last week, my handbrake light and stop light keep flashing, turning off turning back on and i cant think what the problem is. nothing is happenign just the light keep turning on and off. loose wire? connector or what . any ideals
You are running out of brake fluid most likely. Top it up before they stop working...
OOOO will have a look then thanks for the help. what break fluid is ok in a 1.6 16v 2002 clio....dot 4 ok???
check your brake pads, instaed of just topping upthe fluid, otherwise when they are changed it will spill out of the reservoir....
checked the fluid and it is pritty low. wouldnt have thought it was pads, just had mot (sat) and not even a advisory
happened to mine for a while before i decided to check the pads ended up needin new discs aswell...... BONUS!
