Hi, my 182 has started doing something very strange and I wondered if anyone has experienced this, or knows what could be causing it.
When driving at low revs (1000rpm up to approx 2300rpm), in a high gear e.g 3rd, 4th, 5th and accelerator pedal pressed the car stutters and splutters loads (like a rapid missfiring) until it clears its throat again. When it gets above 2300rpm ish, the issue starts to disappear and the car pulls very well beyond this up to the red line).
When this issue happens, it's so bad that the car does not want to accelerate at all as it is missfiring/spluttering so much.
I've swapped out the coilpack with a new one and it hasn't fixed it, also the spark plugs are new (correct NGK ones). I haven't changed the leads though - could it be these causing it?
I did also think it could be a lambda, but the issue feels more ignition related, which is why i'm pointing the finger at the ignition leads. I am also not ruling out the throttle position sensor.
Any input or wisdom would be appreciated though.
thanks
thanks
