stretch tyres
i've seen a set that i want team dynamics
16's n dropped 30mm or 17's n not dropped either with stretched would they do??
stretch tyres are a euro look thing on wide rims , its really just so you can get your wheels out the arch futher whilst still keeping the tyre inside
i thought it was a tad smaller tyre over the wheel which = lower ride as well as being lowered awell as i said in newbie corner i is a clio virgin n i'm being broken in lol cheers for the posts guys n gals
lowers it by a fraction, nothing at all noticable, but you have less rubber in contact with the road so less grip
Surely this buggers up the 1*2's best feature, the handling??
not at all, i have 195 tyres on so the same as normal 172 wheels (regards as to the amount of rubber on the rd) but i have wider wheels, and a wider track = better handling
Until the stretched sidewall comes away from the alloy and you crash into a tree
it can be done, IIRC the standard width is 195 you can try getting hold of something around the 175 mark or just fit the lowest profile 195's which would be better for day to day use. You would need to lower your car as well for them to work as they may look silly at standard height.
15 inch deepdish stretched tyres and slammed or it will look SILLY
Halfrauds rims a nono
for a clio MK2, stretch over 15s, No bigger.
You need some BBS or something, and more than 7J probably 8 or 9
You need to think about offset too
oh and be prepared for scrubbage :)
