Any 1 got any suggestions for me to stop my sub from moving about the boot all the time. Ive heard that using velcro may help but does any 1 have any other idea cheers
Be better making an mdf floor and screwing it down, wouldn't fancy a flying sub in an accident
Also need to secure mine somehow, it's heavy and doesn't move about much (sits on the righ tof the boot above spare wheel) but it's quite a weight not to be secured in an accident.
Whats the best way to secure it wihtout causing too much bother getting at the spare? tah
My MDF floor is a 2-piece design, I can lift out the piece over the spare wheel without moving the sub at all. If you keep the margins tight then carpetting will keep both pieces together, or get some clips to keep things in place.
Ah thats a great idea! Do you have any pics of it? thanks
not right now, sorry.
Earliest would be over the weekend, dont get home before the night closes in.
It's not a tough one tho.
use boot carpet as a template, cut using jigsaw,
slice into sections,
cut out strap holes on section you want for the sub.
Carpet both sections
then fit, either with out without original carpet. If with the original carpets you can velcro the mdf to the carpet if you like?
