subwoofer and amp question...
Car  wrx sti ppp (305bhp)
im getting a sub and amp this weekend and was wondering how do i secure them down in the boot?? anyone got ideas or things they have done/used?
dont use velcro, there are two bolts in the floor you use for a cargo net, you build a bracket an attach it to them :)
cool sounds like a good idea, anyone got any pics of how they have done it, or pics of any u can find lol. cheers
Lift the carpet out of your boot, lay it down flat like a template on to a sheet of MDF or Ply-wood, draw round it, lift it out of the way, cut round your newly marked shape with a jigsaw, then cut it down the middle so it will fit into the boot, and now you have a hard false floor with plenty of strength to hold your sub box and screw it down, and even screw your amp down to it, hiding the cables under neath :D
Don't ever velcro it, do you think it could with stand a crash because i don't think it could, and you wouldn't want a sub in the back of your noggin would you ;)
This is the best way ^^^^^
Very True..
They done tests on 5th Gear a while back where they placed a Laptop computer on the parcel shelf, then proceeded to crash the car in a set up series of events..
At a 30mph collision with a wall, the laptop went flying into the front with enough velocity to remove your head from your shoulders, so just imagine what a sub and box would be like.. Probably take the rear seats out and continue to the back of the drivers seat :S
Id be spending the money on a sheet of MDF and a few screws if i was you lad :cool:
Agree with this^^^ !
I always do my rear seatbelts up as well when they're not in use - should provide some helpful extra restraint should the seat catches decide to give way...
You don't necessarily need to do a false floor. You can drill through the boot floor and bolt it down. Just be careful where you drill that's all.
although velcro is commonly used if i were you id fix it down a little more securely as a crash at high speed could leave you with a sub box thats smashed to bits from the impact on your head;)
