MattT said:You need to get some grease on the hinges Giles.
There is a guide knocking about somewhere - I think fubar did one.
But anyway - the main bits...
I'm not sure what the ph1 sunroof is like but the ph2 lifts out once the clasp handle is undone. You'll see a small horizontal bar inside - the idea is to put a small plastic sleeve around this (like hosing but much much smaller) and it makes the sunroof clamp closed that bit tighter. The 'hosing' isn't seen either.
Next thing is to slap lots of grease on the hinges towards the front of the car - it's this bit that rattles (at least it did in mine). Be carefull putting the sunroof back in as you don't want to get grease on the interior cloth etc.
Once it's in - it'll be rattle free - I got mine replaced after 2years and the replacement started to rattle until I did this. The car is now lowered and it still doesn't rattle when closed/open whatever!
Certainly cheaper than an electric one!
