Supercharged 182
Robbie Corbett
Trader Rating - 0%
0   0   0
I think these engines are tough little things and wouldn't have an issue with 250 with sensible little upgrades (oil cooler, arp big end bolts etc) together with sympathetic driving. The rotrex is actually significantly kinder to the engine than an eaton or turbo from a peak cylinder pressure at low RPM point of view.
I would have more of an issue keeping up with the gearbox changes.
Cub.
Trader Rating - 100%
2   0   0
Given I’ve owned a rotrex supercharged clio, I wouldn’t be running more than 250bhp at the fly, let alone the wheels.
Cub.
2   0   0
I didn't know you previously had one? Did it explode?
Sorry, I also read the advert as 257 at the fly not the wheels - I would have big suspicions about that figure haha.
Didn’t blow up, no. But I’d say around 250bhp at the fly was close to the “safe” limit for a car you want to do regular miles in….I regret selling it now, but life goes on;
Robbie Corbett
Trader Rating - 0%
0   0   0
Well, thats this afternoons slacking organised - thank you.... I think :ROFLMAO:
Cub.
2   0   0
Suspect I will get to page 44 and also conclude that you shouldn't have sold it?
Highly likely. End spec was;
Engine
- 182 Engine, rocker cover painted white, block painted black.
- Rotrex Supercharger kit with associated boost pipes.
- Gen90 ECU
- Toyosport Intercooler
- Custom Roose Motorsport hoses
- Samco Coolant hose kit
- Magnecor Leads
- Mocal Oil Cooler
- Mocal Catch Tank
- ARP Rod Bolts
- K-Tec / Vibratec Solid Engine Mounts
- Matched Inlets
- K-Tec 3.5" Recessed Supersports exhaust
- Megane Injectors
- 102k miles, new cambelt, dephaser, aux belt, megane keyweyed pulley and megane crank bolt fitted and timed by Dan@SJM
- Powdercoated inlets, fuel rail guard, engine mount and brackets
- Bosch S4 battery
- Air con delete
- Nimbus heatshield
- Mapped by RS Tuning, Rolling Roaded at 248.7bhp and 220 ft lb.
Transmission
- New Gearbox
- Gripper LS Diff
- PMS Race Shifter / Gear linkage
Handling
- AST 5200 Coilovers with custom spring rates
- Northloopcup / BIGASH Roll Centre Kit
- Whiteline ARB
- Eibach Hubcentric Spacers (16mm front, 5mm rear)
- PMS Solid Top Mounts and Strut Brace
- Eibach Camber bolts
- -2.5 deg camber at the front, 10 mins toe. -1 deg camber at rear
- PMS Stud and Nut kit fitted
- 15 Speedline Williams wheels with Dunlop Direzza 03g tyres
- Cup wishbones fitted
Braking
- Brembo 4 pots (Megane 225)
- Custom HEL braided lines
- Custom Chris Powell Brembo brake brackets
- ABS delete (incl. Loom), full Cup brake lines and MC setup fitted
- Ferodo DS1.1s, Ferodo DS2500s rear.
- Brembo grooved HCs (Front)
- Renault OEM Discs (Rear)
- ATE Super Blue Racing brake fluid
- Fog lights removed and no arch liners
- brake ducts
Interior
- 2x Sparco Evo 3 Bucket Seats
- OMP Subframes
- OMP 3" Harnesses
- Custom Oreca / Renaultsport 330mm Steering Wheel
- OMP boss
- 6 point Roll Cage
- K-Tec Rear Boot Mat
- Renaultsport Front Mats
- Sony CD Player with Ipod Connector
- White Dash Strips & Gear Insert
- Alcantara Handbrake Cover
- Rear Strut Brace
Exterior
- Cup Splitter
- Trophy Spoiler
- Renault Sport 197 Badge
- Porsche 'Bee Sting' Aerial
- Lockable Aerocatches
And it looked like this;
Robbie Corbett
Trader Rating - 0%
0   0   0
Engine
- Gen90 ECU
- Magnecor Leads
- Mocal Oil Cooler
- Mocal Catch Tank
- ARP Rod Bolts
- Matched Inlets
- Megane Injectors
- Bosch S4 battery
- Air con delete
- Nimbus heatshield
Transmission
- New Gearbox
- Gripper LS Diff
Handling
- Whiteline ARB
Braking
- brake ducts
Interior
- OMP Subframes
- OMP 3" Harnesses
- OMP boss
- 6 point Roll Cage
- Rear Strut Brace
Exterior
- Cup Splitter
- Trophy Spoiler
Thats ridiculous, I've just mentally totted up the cost of the parts alone and thats also ridiculous... anyway, stop spoiling my read :ROFLMAO:
