I had mine done a few years back and I just supplied them with the valves.Good afternoon,
My 182 is going in for cams, cambelt and arp rod bolts soon.
I'd like to add supertech valves to this list, but do I need valve springs and stem seals as well as the inlet and exhaust valves?
Thank you!
I would recommend getting the head port and polished, you need every little bit of help to get any great power out of the F4r, its not like a K20 or K24 where a map and breathing mods give huge gains.Valves will definitely be done, the question is if springs and stemseals need to be done as well?
Got an RS2 so won't be needing any port and polishing 👍
Get the valve guides checked for wear and replaced if ness. Stem seals need to be changed as a matter of course.
Not sure if you need spring change, maybe 197 if they are better than 182 ? Unsure if they are or not but it will be matched to cams.
You will need to check installed height of the valvesprings with supertechs in, especially if using cat cams springs etc. My 197 head needed custom 1.5mm ish shims to get the correct installed height with catcams springs, so the spring pressure is correct.
That's what the guy doing the work said as well!
No idea on mileage, the engine has been changed after spinning a bearing in 2016, done another 33k miles with quite a lot of track miles since then.
@Christopher. Long time ago, but maybe you can remember approximately what miles the engine was on when fitted?
