supressors ?
Car  ibiza cupra
i wired up a supressor to the live wire on my amp as told by the place where i got it from and posted a thread about it on here and got told that it was in the wrong place and that it would proberly burn out in no time. here is the pic
well any way it did so had to take it off to get my amp working again but now i have the annoying sound of reving back through my speakers. any idead of where i can either A. get a supressor with a bigger gauge wire or B. wire up a new one of these to stop the bloody noise
ta very much
ta very much
Easier just to run your live wire on the opposite side of the car from your amps phono wires. (live down the left of the car, the phono cables from the amps to the head unit down the drivers side). This should eliminate the interference you are hearing when accelerating.
As above ^ extremists wil even buy shielded cables. But the easy fix is to run them opposite sides of car. Thats of course assuming you have the amp in the boot. Or somewhere where this is possible. If like me u have it under your seat then learn to live with it. lol.
Also make sure your ground is good, as this can cause the problem. The ground needs to be touching bare metal, so sand away the paint around a blot in the boot which attatches to the chassis, and put it on there.
ive already done all of these things and this was my last resort and did work untill it went pop
