suspension problem!!!!
  NEED V6!
When ever one of my mates get in the passenger side when I' m sitting in driver's seat as sooon as he gets in the car, the suspension creaks does this happen with anyone else or have i got a problem.
  182 clio sport
Hi,
Mine did the same thing.
Took it back to dealer and got them to check it under warrrenty.
Said everything ok.
1 week later my drivers side damper has colapsed and died.
May not be same problem as you but maybe worth a quick look.
Look for oil running down the strut,
hope this helps
  Lots of Alfas
is this with the handbrake on?
yeah most of the time, what do you recon problem is​
Its completly normal, when theres more weight in the rear it pushes the suspension down which causes the angle of the wheel to move which will drag the rear brakes. This causes a loud creaking noise. Hope that makes sense!
Try jacking the front of the car up with the handbrake on and listen for it then.
