Suspension track settings
Hii there,
has anyone tried any non-expensive suspension improvements? Like running different camber setups? Etc for improving handling and so forth on the track? (we are doing trackdays - and illegal street racing! - nothing major)
the camber is not adj on the 172, you need to buy camber correcting bolts. The clio cup racers use fixed value camber bolts althought you can get adj bolts, or make up your own adj set. Ford motorsport sell some very cheap and effective camber corrective bolts which you can adapt easy.
Toe should stay a tad out as its a high offset wheel.
Castor is non adj unless you adapt some adj top mounts.
Rear camber is adj by means of shims inbetween the stub axle.
