suspensions lowering
Car  1.2
quite a few people have said about different kits. i wanna buy a suspension kit springs and shocks, depending on the price maybe adjustable dampers too. i wanna lower it say 40mm.
which make should i buy or should i save and buy kf coilovers. never modded a car before so i wanna do it right first time but dont wanna spend a bomb on me motor.
can you modders help a virgin modder hehehe
been looking at Gmax, apex, koni, and spax which should i buy ???????
i bought the koni 35mm kit which was a lovely kit for the price, but just didnt lower the car enough (as i have 15s on lower profile tyres)
if you know you deffo want a 40mm drop then you may as well go for the koni/apex kit, however the handling is so much better on coilovers its worth paying the extra. FK's are only 445 :)
personally i'd put 14 or 15" wheels on it with coilovers and uprate the brakes, considering the engine size this will make it surprising on twisty roads ect.
Go with the Apex 40mmor so kit then its quite cheap and good value.
personally I'd spend it all on suspension its makes the biggest difference. FK coilovers then if you have some spare some Cup alloys or similar light weight alloys no bigger than 16 though personally.
you know where its at matey! 17's are so ghey ;)
jonnyjogpants said:
why dont i need them i thought if i was lowering the car i need to correct the camber....
many thanks
depends on the kit some have a maens to adjust built in, some just don't need it. you do need to get it checked tho, and the toe setting
