swapping between RS tuner maps .......
  Inferno 182 FF
Can this be done, ive just put the ron 98 map on and over the moon with it but just wondering if i now buy the over-run map can i swap and change between the two using the RS tuner programme??
DaveDreads
You can load as many maps as you like with the same unit,
I put my car back on the the oem map once because I forgot what it was like,
put the 98ron map back on after 5 minutes, car felt broken.
