TAKING OFF AND SPRAYING REAR BADGES?
Car  172 ph2
Just a quicky, i assume if you take the rear renault sport and clio badge off you have to buy new ones to replace? or can you just spray the exsisting ones and put them back on?
ideally you replace them but you can remove the sticky stuff then re apply some double sided tape to to shapes to fit behind the letters then re stick . just make sure you get them straight . use maskin tape to set a level line across your boot .
Actually the "CLIO" one is only held in with two clips either side. Use a knife or screwdriver (wrapped in a towel or something to protect paint!) and prise it off...be carefull you could break it.
I pop mine off all the time when im cleaning :)
