Hello. My Clio 182 has been having trouble starting recently, the engine fires but does not tick over and start. Normally, it does this first time, but on the second turn of the key, the engine would start.
However, this weekend, it would not start at all and had the get the AA out. They managed to start the car by removing and cleaning the "crank shaft sensor" - apparantly it was causing the ECU to not detect engine revs (or something). I went to a Renault dealer and they advised me that I need to replace the TDC sensor at a cost of £173.
1) Is the crank shaft sensor the same as the TDC sensor? I'm guessing it is.
2) Now that the the AA has cleaned the sensor for me, do I absolutely need to get it replaced? Will it go wrong again? £173 seems a lot of money for something so little.
3) How do I clean it myself should I need to? The AA man had to remove a few bits before he got to the sensor. Seemed a bit fiddly.
Searching on this forum would suggest that this is a common problem on Clios/Renaults.
