Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
Put simply the TDC sensor or crank angle sensor merely reads teeth on the flywheel so the ECU knows the positon (in deg) of the crank, and thus the position of any piston.
mostly used for ignition and injection timing/sequensing.
if this was broke, you car wouldnt work yet alone idle.
