Technical data
Car  VX220
Somebody Please point me in the direction of the guide where you can view the technical data on the dash. When you turn your key and press the washer stalk button.
I have looked for ages but no luck
chris
Put your key in , before you turn the key press the end of the stalk and hold it in then turn the key to position 1 .
Cheers, i knew what to do its just i wanted the codes.
The codes which i have come up as T & H
t mean an injection fault has been detected for a minimum of 4 seconds
h means an oil level sensor fault has been detected. Resistance from the sensor should be between 6 and 20
The car seems fine so should i worry about any of this?
Chris
i did this on my clio 2 reset my fuel left trip comp and my needles got stuck when they did full sweep
