ex-Chinese Dave
172 Cup
I’ve noticed sometimes that when taking the key out of the ignition barrel, the very tip of it seems to be difficult to pull out. I’ve also had it a few times where when I’ve turned the key to start the car, it hasn’t turned in the barrel. It’s nothing to do with the steering lock as I know that you can relieve the pressure by turning the wheel a little. I’ve just read up on here and some people recommended the usual WD-40 or graphite powder put into the barrel, but with the age of the car I think it’s something that’s going to need replacing sooner or later. What are my options on this? It’s obvious that a new barrel will come with the key but does anything need to be coded to match the immobiliser and alarm also? Can you recommend what parts would be needed and the best place to buy them from, also?
This is a continuing theme on my car in that at almost 145k parts need replacing if you want to keep it alive. It’s turning into Trigger’s bleedin’ broom!
