Testing auto-levelling lights
Is there any way I can test if the auto-levelling is working - seeing it move the lights up and down?
My managers Saab always move the lights up and down when you turn the lights/ignition on. You can see the lights moving up and down when its parked facing a wall.
Is there a test function on the 182?
Ste
Put the car infront of a brick wall and measure where the ligths are. Then sit on the boot. The rear axle has a sensor on it and will/should recognise the rear axle getting lower.
Dealerships can adjust the lights using there computers.
  TDI tyre shreader
I think there is somthing wrong with mine as the passenger side seems to be very low like this _ - if you get my drift is that normal?
The passengers side is meant to be lower I think.
  The Jinx
Look at the headlights on any slope. If you go blind then youre auto-levelling is buggered.;)
Xenons are so bright they have a shield-like thing in front of them and the auto levelling makes sure the full power of the beam sits behind this.
