bozothenutter
		Anybody know of spacers in the 5-7mm range that have a centerring (hubcentric)?
I'll modify the original center to make it fit.
They don't need it because there is still enough space to locate the wheel on the hub with anything under 10mm.
Would 5mm even make a noticeable difference? I went with 10mm stub spacers on the rear and could probably get another 10 easily
Depends what wheels you've got and what the offset is to start with.
I had 10mm hub spacers on the rear with cup turinis and found it too much so dropped down to 5mm.
