cant seem to find the gdi website?
been looking at these, anybody ever has any experience with them?
http://www.yozzasport.co.uk/proddetail.php?prod=jenvey_throttle_body_kit_f4r&cat=149
thats just the hardware, no ecu
i'd go to emerald, they do a jenvey kit for £2K +£300 mapping (which includes 3 switchable maps ie 95RON, 98RON and economy or safe mode for example, maps are switchable via a dash mounted switch)
the emerald would be more of a DIY install, but at least that way you could do it a hell of a lot neater, its the details that count, ie hidden ecu's, hidden throttle cable, no secondary wiring loom (ie retaining the stock loom completley! plug in the new ecu and off you go)
not to hijack a thread here, but fred, you say an ecu shouldn't b in the engine bay, has anyone relocated their ecu inside the car? i've not seen anyone on here discuss it, but should this be common practice, especially with an expensive aftermarket unit? is it difficult/ dangerous just to extend the cabling?
The Emerald ECU does not have a knock sensor built in. Can cause massive engine failure if fueling is incorrect.
Stick with GDI/Omex.
we can supply an ECU extension cable if you wish to put the ecu in the car.
Andy
the emerald kit doesn't have all the fancy brackets etc etc of the omex/k-tec kit, but tbh i don't think that kit is the tidiest install anyway (in my opinion)
i'll be using the emerald stuff for the F4R's when i'm up and running, if there is interest then i'll offer a ITB conversion, but don't be expecting much change from £4K
LOL
hidden ECU and hidden throttle cable.... what a waste of time and effort.
Anyways, TB kit, GDI/OMEX or Ktec kit (same kit) is your best bet if you want an easy simple, fit and forget setup.
Otherwise by all means go the DIY route!
not if you want as oe looking as possible install
the whole point of an off the shelf KIT imo is anyone can install it, they should've spent a lot more time on the loom, no need for a separate loom, the OE loom will be of a higher quality, so why not use that?
ecu's especially aftermarket ones imo shouldn't be in the engine bay (even if the manufacture says its fine)
you do of course realize that you have just completely contradicted yourself don't you. a couple posts ago you where saying how your kits will be better as you can make all your own brackets and make the install 'much neater' which would be a HUGE amount of work..not forgetting the fact you have just said your kit will be well over a thousand pounds more expensive! and now your saying that a kit 'in your opinion' should be able to be fitted by anyone right? so please explain to me how fitting a kit that will cost more money and needs loads of messing about is 'easier' than connecting 2 wires into the standard Renault loom and fitting a fully comprehensive kit that can be fitted well inside a day 'by anyone who has half a brain' by following a very clear installation manual.
no mapping, no fabricating, no machining, no hunting for parts. yea your right. id go the diy route as well
as for the 3 maps thing. please explain to me how you map an engine for economy? any engine runs at its most economical when it is at lambda 1. so since an omex will be running full lambda control at anything under 70% throttle which will cause it to run at lambda 1 im a little confused how you believe that can be improved upon? but i await to be educated???![]()
I'll be watching this thread. Looking a tb's and possibly cams in the summer. K-Tec is the front runner for me so far as it looks tidiest. Not the most mechanically minded person so would rather it as problem free as possible!
Ahhh.... my bad. Thought the GDI one was calibrated for longer trumpets/cut slam panel.The ktec kit is the GDI/ Omex kit![]()
But that means cutting/removing the slam panel right? Don't wanna start butchering my car tbh
