Throttle body....how hard isit to change?
  No car
Hi guys, I cleaned my throttle body the other day and I found it quite straight forward, I have a warning light come on in the instrument panel! I've been told I need a new throttle body. I said To the guy at the garage I could do it myself but then he mentioned how it has to be programmed to the car. Is this correct? I was gona get a second hand one off the forum, fit it and hope for the best. What u think guys?
  No car
Really! So basically just unbolt take off the plug and then the pipe swap over put everything back and job done?
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Haynes manual 1 spanner difficulty rating.... be careful! lol at the scare tactics though - the dealerships used to do this also. I have seen a K9K EGR valve lose its adaptives from being unplugged before though but thats a different matter.
Out of curiosity/stupidity i'm gonna ask... what light have you got on the dash (amber ZigZag?) and what made the garage say you need a new TB?
Mick
  Golf GTD Mk7
Like Mick says, what light have you got on? If the body is knackered the car will be driving s**t, not just recreating Blackpool on the dash. FYI i'm selling a TB ;)
  No car
Mick
yeah it's the amber zig zag in the box! When it comes on I'm limited to 3k revs. So they said its most probably the throttle body. Gona cost around £170 (parts labour and vat)
But I cud do it myself :-s ?
  No car
Just in case I do need to change the throttle body, how much are u looking for yours Jonny?
  No car
Yeah I cleaned it the other day, that plug was jammed up tight! Managed to get it out after 15 mins of poking and prodding it! Yh I was gentle and a lil bit snapped off mine too!
  No car
Jonny, can I provisionally purchase that? Just gona try and see if it's the throttle or the wiring. Then if problem still ain't solved I'll have it off you?
  DON'T SEND ME PM'S!!
Plug on the throttle body makes me rage, snapped a bit of the clip off mine, and i was being gentle :(
you're a ham fisted oaf though ;)
push the plug ON apply some pressure to the clip with a screwdriver (careful, it's plastic!) , then pull the plug off. very easy
  HBT 172 Cup
To late now :p I remember when i first did it on my mates 172, i pretty much destroyed the plug lol cracked in half pretty much :/ The fists of ham were strong that day
  Golf GTD Mk7
lol they are so easy to remove. Try doing the airbag ones without getting frustrated and cutting the buggers :mad:
  HBT 172 Cup
lol i removed my steering wheel in about 5 minutes, airbag wires were easy!
Tell you what you remove my throttle body plug, and ill do your steering wheel. haha
  330i. E30 Touring.
Two plugs/connections that always gets me raging is the starter motor spade connection and the gearbox reverse sensor plug. I've always got cold hands by this point- on several occasions i've talked about torching other people's cars over these two little f*****s.
