Throttle Body , Pedal potentiometer and Injectors not firing problems
  clio 172
Currently my clio wont fire up since re-fitting the engine.
I have noticed that the Butterfly valve does not open when I press the throttle and try to start .
The car fired up when manually opened the valve and sprayed quick start into it.
Other check I have found is that I am getting a spark and the fuel is getting to the injectors rail but the injectors are not firing as they are dry .
Would the injector rail be linked to the throttle body / Pedal Potentiometer issue ?
I have got another pedal to try and just trying to source another throttle body.
cheers
Finch
