Similar... you need a camshaft setting bar, crankshaft setting pin (Note its NOT a lock pin on the K4J/K4M) and a K4x specific camshaft sprocket tool.
The basic process is very much the same though except you MUST do the water pump as well as they're pretty much the 2nd biggest timing belt killer on these lumps.
