Torque setting guide?
There is a PDF file somewhere on here. It's the workshop manual for the f4r.
What ones you after?
That would be great!
Made a schoolboy error with leaving a calliper loose yesterday :(, managed to source the problem in enough time thank god.
Just want some torque settings to make sure everything is correct
Front Hub Nut 280 NM - 207 ft lb
Wheel Nut 90 NM - 66 ft lb
Lower strut bolts 105 nm - 77 ft lb
Brake Carrier bolts 100 nm - 74 ft lb
Brake Caliper Guide pin bolts 40 nm - 30 ft lb
Brake disc retaining screws 20 nm - 15 ft lb
There's some off hand. Have a search for f4r_730 workshop manual it's on the forum somewhere.
