Toxic Fume Warning Light
Andy8CH
Car  Clio 172 Mk2
Had this warning light come on last night.
Haven't noticed any change in the engine & the engine is not in limp home mode ( it will rev above 3/4k )
Is this likely just to mean one of the sensors is faulty - or is it likely to be something more serious?
Also should I avoid driving the car until I can get it to a dealer to get it fixed?
Might just be a damp lambda mate. Mine did this a couple of weeks ago when I drenched the engine. T'is fine now.
disconnect the battery for more than half an hour.
then try it again.
note - make sure you have your radio code!
yeah, this light will clear, i had a damaged lambda plug, fixed it, but the light stayed on, the light cleared within a week
no need to worry imo
Cheers for the replies.
was still on, so I did the dashboard diagnostics which showed a 'h' fault - according to edde's post is an oil level sensor fault. Anyway I cleared that and the light went out!
