TPS Throttle boddies
  182cup & 172 racecar
I'm obviously running ph1 tps for itb's. Renault do not do them anymore, so does anybody know where would be the best place to get one from, or have a part no for one.
NorthloopCup
Would you not be better off swapping it out for a different one Tony? It may require a change of the wiring and recalibration in the ecu, but only small fry in the grand scheme of things.
Have you looked on euro car parts for a tps? Or eBay maybe?
  PH2 172
Old unit will have a manufacturers No on it?Bosch,Siemens,Simtec,Lucas?
Doubt if it was a bespoke piece for Ph1 172.
Surely someone on here has a Ph1 throttle body with one on stashed away?
  172 Cup, MK1 172
If it has PF1c (clockwise) or PF2c (anti-clockwise) stamped on the side they are available as a kit (inc new connector/pins) from AT Power for £40 plus shipping.
Hope this helps.
Hope this helps.
Ah thanks, yes they are at power itb's, that could be the answer.
Didn't think of that. Thanks
