Transmission - help!
Ive got a kind of whining coming from the nearside front of the car, which goes when I dip the clutch (into neutral). Its not a wheel bearing - I need a new one of those anyway and that makes another noise!
It comes from about 30mph on, but it doesnt matter which gear Im in (so unlikely to be a worn gear). Its difficult to describe, but sounds like a light grinding noise and gets worse when Im off-throttle. So if I accelerate, even slightly, it gets quieter.
What could this be? A driveshaft? Synchromesh? Help! :confused:
Cheers - is that expensive?
Can I use the car for another 1000 miles or so? Or is that suicidal? :confused:
Just dug out the Haynes manual and it would definitely be an engine out job if this is the case!!
you can keep using it to a point but the noise will just get louder.to change the bearings it would req the gearbox removing and completly stripping.might be more economical to find a recon gearbox.
Its a bit crap really as the Willy gearbox is meant to be tougher than the 16V one, yet my 16V one was fine when I sold it at 105k miles. The Willy has 57k miles!
If it costs more than £600 to fix the box alone (ex-labour), then I hear Renault can supply a brand new Willy box for about that price?
