Tyre Pressures
Car  ph2 172
hi all
what is the tyre pressure supposed to be on the front tyres of a mk2 172 with standard alloys?16" inch ones!
thanx
wot pressures would be right for track use ive herd it should be 10% more than road so 36 psi front and 33 psi rear ?
thanks cal
thanks cal
Best have a play round at the track. Only reaosn you overinflate it to trey protect the side walls.
What does it feel like when the tire wall is reaching its limits? Or is it one of those things where it feels fine till its kaput.
32f, 30r.... just make sure they are COLD when you do them, a trip to the petrol station will up the reading by 2/3 easy! so put abit more in then adjust them when back home after been sat a good hour or two :D
