Tyre Pressures
  Golf R
29/29 worked very well for me after my camber was setup etc
i was advised that by the time the tyres have heated up they will be running about 32psi
MRBILLYUK
  FF Jeden Osiem Dwa
I'm sure the original question was about the tyre pressures for Michelin PE2's ;) not personal preferences or other brands of tyre ;)
Like mark5290 says , the recommended pressure for " PE2's " is 33 front and 30 rear :rasp:
  VaVa
You might think you're clever, but have you realised he has a 172? Thus there is no recommended tyre pressure for PE2's as the 172's standard fitment was ContiSport Contacts :rasp:
How do you like them apples :rasp:
MRBILLYUK
  FF Jeden Osiem Dwa
For a start it just says PE2's so i assumed it was for a 182 . Also it doesn't say what fitment 195's as in the 172 or 205's as in the 182 . Either way the recommened tyre pressure for a 172 and 182 is 33 front and 30 rear , whether it be PE2's or Contis ;) I assume you haven't got an owners manual to hand :clown:
