Tyre Pressures
29/29 worked very well for me after my camber was setup etc
i was advised that by the time the tyres have heated up they will be running about 32psi
I'm sure the original question was about the tyre pressures for Michelin PE2's ;) not personal preferences or other brands of tyre ;)
Like mark5290 says , the recommended pressure for " PE2's " is 33 front and 30 rear :rasp:
You might think you're clever, but have you realised he has a 172? Thus there is no recommended tyre pressure for PE2's as the 172's standard fitment was ContiSport Contacts :rasp:
How do you like them apples :rasp:
For a start it just says PE2's so i assumed it was for a 182 . Also it doesn't say what fitment 195's as in the 172 or 205's as in the 182 . Either way the recommened tyre pressure for a 172 and 182 is 33 front and 30 rear , whether it be PE2's or Contis ;) I assume you haven't got an owners manual to hand :clown:
