Uch control unit
  Renault clio
Hi, can anyone help, I've got a renault Clio 2002 and the wipers don't work, after abit of investigating I've found out its because of the uch control unit, can anyone recommend where I can get a new one and get it reprogrammed, as the main dealer is quoting me silly money! Many thanks
  Clio II ph1 1.6 16V
Happy new year guys!
There are quite a few threads about uch and did not want open a new one, hope it is ok.
A friend of mine asked me to get him a UCH for his clio, which is mk2 ph2 2004 1.4 16V. I have got the part number 8200621762.
The only place i have found the uch on ebay, but there is the tricky part. The ads on ebay is for 1.2 v8 see the link below
https://www.ebay.co.uk/itm/Renault-...h=item56bd07c134:g:RVEAAOSwfgRcGQuY:rk:2:pf:0
Now my question is, that is it ok to buy that uch as it states it is for a 1.2 v8?
Brigsy
  T.Turbo
The ecu, key and uch are matched so wont work unless you swap immobiliser chip from old uch. Get the old one repaired or buy a full set to suit the correct engine.
  Clio II ph1 1.6 16V
Ok I see, so it means there is no other way like using clip to reprogram the secondhand uch?
Brigsy
  T.Turbo
As far as im aware you can only program a virgin uch with clip to suit another ecu/immobiliser. I guess if you had key to suit uch you could get somewhere to reset the ecu immobiliser, but still most likely cheaper to buy a working full set.
  Clio II ph1 1.6 16V
Thanks for your reply, i have spoken to him and let him decide which route he goes.
