Hi,
I bought a used 172 clio that has around 100k miles on board. Before this, I run a 1.2 16v clio which has no more than 20k miles, so it was like new. When I switch to the 172 I need a little time to "learn" how to shift, because it is a little different. Although it was different, I did not understand why moving into second gear the gearstick has a smaller amount of movement than moving into 4th gear. It's that normal? Only the second gear has smaller movement.
Thanks and hope you could help me,
Radu
Radu
