My 182 has been developing a slight mis-fire for a while.
It only occurs (or is noticeable) at light throttle openings e.g. cruising at 30 in 3rd. Once you put your foot down a bit you cannot notice it e.g. 70 on motorway. But at idle when it is having a bad day it will put the flashing engine warning light on.
This seemed like injector faults I've had in the past so I swapped the fuel rail and injectors from the race car but it made no difference. So I swapped the plugs, lead and coil pack from the race car. While doing this I did a compression test that checked out all cylinders running similar compression. Changing the ignition components still didn't change the mis-fire.
I'm thinking about it being a wiring fault? I'll get my rs tuner on it while it is doing it and look at the sensor readings. I'll also try swapping some other bits, TB, sensors and TDC sensor from race car but non of them seem likely to me.
So I'm wondering if others have had similar and what the solutions were. Thanks.
