So when my missus when to start the Clio to rtn home from work late last night, the car
wouldn't start.
Ignition ON, immob light goes from flashing to steady red, then extinguishes, turn the key
& starter motor engages briefly (about 1 second) possibly a minor crank of the engine but
nothing else, just won't start.
Repeat starting procedure and the car just responds as above?
So I told the missus over the phone how to bypass the immob** and hey presto, car started first time!
(**Ign ON, press & hold c/l button on the key, turn key back one click (with c/l button pressed in), then back to 'Ign ON' position (c/l button still pressed in) & turn key to start engine.)
Of course she was most impressed with my telephone advice :wink: but she does use the Clio frequently & doesn't want to be mucking about with bypass tricks to get the car started.
Question.. What is causing the problem?
Is it..
a.) the transponder key?
b.) the immob transceiver in the car?
c.) crank shaft position sensor or..
d.) something else?
Please help... I do like to keep the missus happy & don't want this to prove terminal!
Many thanks, Steve
wouldn't start.
Is it..
d.) something else?
Many thanks, Steve
