V6 Airbox CAI
Car  172 Cup
Was just wondering if anyone knew what the best cold air feed to use for the V6 set up. I have no fog lights on the car so running from the holes there wouldn't be a problem.
Not really any benefit from a CAF, if you really wanted to do it then you could run a feed from the fog but don't connect it to the airbox, just have it coming up and directed towards the airbox opening.
Do a quick search, has been discussed many a times
102mm ducting, but it won't fit behind the headlight. I believe 2x70mm will fit though. You'd have to make some up to fit. Ie. 102 into 70 back to 102. Bit of messing for no benefit tbh
