V6 Mk1 Stereo Loom
Car  Evo MR FQ300 & Clio V6
Does anyone know if the Mk1 V6 stereo loom is pre wired for sat nav?? I want to fit a blaupunkt sat nav stereo that requires the following on the standard stereo ISO plug (Power one)
Speed pulse signal - Got this from the speedo on my Williams
Reverse signal - Got this from reverse light on the Willy
As the sat nav was an option I just wonderd if they would have these signals available for the upgrade or if they would have to add them in.
Simon
You can get the speed pulse indicator from the standard steroe wiring. Im not sure about the reverse but Ill have a look for what wire you can use if you want. Easiest just to ignore it and not tell the car its ever going backwards.
Thanks for that. The amount of time the car would be in reverse the signals not worth it - Glad to hear the speed ones there.
Next problem will be with the heat reflecting screen. I guess mounting the GPS aerial in one of the rear quarter windows would do.
Thanks for that!
