Yer remove the door tray and then remove the screw in the door handle release, then just give it a tug from the bottom and work your way around the edge of the door, to release the clips.
i think they just screw into plastic clips which could be broken and just turning with the screw. Try using a flat headed screw driver to leaver the the screw head up as you turn it with the torx. If that doesnt work you might have to use something more drastic and break them.
you unscrew all the screws off the door handle and side pocket then you slowly pull the door panel starting from the bottom up and unclip all the clips then once all the clips are loose you have to pull slowly or you bend or snap the panel because the panel is stuck on as well with some kind of grey gum which is really sticky stuff once thats done the only thing thats holding the panel in is the top part of the panel which should come off real easy.
