VHS to DVD [help me please]
Has anyone done this?
We already have the hardware to feed the video via firewire, and have captured a test sample using Windows Movie Maker. The resulting file is a wmv, and we need to convert and burn to DVD so that it can be played in a regular DVD player.
Or;
Any combo of suggestions welcome. I'm guessing this will all be easier to do on a Mac (iMove/iDVD?), which is fine, so Mac OSX suggestions also appreciated. If iMovie can import from DV devices and spit out a DVD dmg, that would be epic. Off to do some more research into that...
Danke.
Hmmm I'm not so sure it's that simple from what I'm reading. It appears iDVD can't import wmv files. Although I don't know much about iMovie and what it can do. I think I may just purchase a 6-9 pin 1394b cable and start playing on the MBP instead of Windows. I think it's going to be easier for this kind of video editing stuff.
EDIT: Scrub that. It looks like iDVD can import from a DV device and burn straight to DVD. Thus negating the need to use Windows at all. Plus my keyboard will glow throughout the process. Even better.
windows movie maker live does it not an issue if your on vista/7
Windows Live Movie Maker in W7 would not import in colour. We used an old XP machine which already had the original Windows Movie Maker, and that worked a treat (but output as wmv)
Gally, it's not for me. I'm trying to help someone else who has a lot of old VHS tapes that need archiving.
As Tom said, it looks like all I need is iDVD and its one step DVD process. Apple, you f**king PWN.
If you can get it into a .wmv out of Windows Movie Maker then can't you just convert it and burn it using Nero?
Thanks but it was a piece of piss in the end anyway. iDVD was unable to capture the feed for some reason, so I used iMovie to grab the video, and then converted & burnt with iDVD. Worked a treat.
