vibrating & Knocking noise - driveshaft?
-KarL-
as above when i put any power down i can feel and hear a knocking noise through the pedal and in the car,
drive shaft maybes? or can a wheel bearing do this?
thanks
karl
  Golf GTD Mk7
if it is the drive shaft you will hear it when turning a certain way while applying the power. Doubt both have gone. The noise will stip when you remove your foot from the accelerator. If that makes sense.
-KarL-
yeah its more so when i turn right. and any sort of power going straight i can feel it.
i had a new driveshaft put in 6 months ago aswell :dapprove:
hmh
  Renault Clio RS 172 ph1
As an idea - just worked out with strong vibration, was caused by inner CV Joint of the right driveshaft. One of 3 bearings in the joint failed.
  182, SQ7, Trafic
This!
Caused by being too low, I've done two in the last 6 year!
