vibration through clutch
Car  b/g 182, meg tourer
i have fecently had a full cambelt kit and aux belt kit changed on my 182, but i am noticing more vibration coming through the clutch pedal since having it done. is this normal? you can feel it more on a cold start. but i noticed the first time i drove the car after the belt changes that there was definatly more vibration.
oh and i forgot to mention... its vibrating when its at the biting point.
ok, is that the one on the left with 4 bolts? this one...
shall i undo the 4 bolts slightly, pull it forwards and re tighten?
will give that a go. cheers danny.
just wondered if it had anything at all to do with belts/tension etc. and if it was anything to worry about.
doubt it's anything to do with the belts themselves. Maybe something that's been disturbed, the engine does go right up and down several times in the process of the job, and a lot of sensors and bits are unplugged so it's easy to disturb things. Highly doubt it's serious :)
thats good news. my pocket is pretty empty after having a both belts/kits changed 2 weeks ago.
thanks a lot for the help danny :) much appreciated.
