Highly doubt the numbers are available anywhere besides Renault or anyone who has raced an F4R with a
serious budget, not just bolting tried & tested stuff on (i.e. works teams). And then of course is the "what are you going to do with it?" Unless you have the money to CFD & develop a new head/intake manifold there's not much point in working it out.
There are a few people keen on numbers who may have worked it out?
MG cup NorthloopCup?
However you could be an awfully good club member and do some little experiments & work it out for us?
I apologise if you already know all of this, but you'll need:
Engine speed (easy - look at the dash for an estimate!)
Manifold air pressure, P (can you see this via cheapy OBD
chip?)
Intake temperature, T (you definitely can see this via a cheap OBD!)
Air density, Rho (google)
Molar mass of air, M (google)
Bore & stroke of an F4R (google)
PV=nRT can be substituted with density & rearranged to give the actual volume of air in the manifold:
V=(Rho*R*T)/(P*M)
Then stick that into the volumetric efficiency formula (google) and Bob's your uncle!
(Again apologies if you know all of this)
Be careful with units. They all need to be SI so temperature in Kelvin, engine speed in Rad/s etc.
For extra man-in-shed points do it across the rev range. Volumetric efficiency changes with engine speed and if you were to graph it, it should virtually mimic the shape of the torque curve (IIRC). Obviously at high revs when you've got high mechanical losses (due to friction) and a very different thermal efficiency (due to each cycle taking 1/7th of the time that it does at idle) you may find the curve differs a little from the torque curve.
EDIT: Need to learn to type faster...
