Yesterday we started on getting the cylinder head off and off to be skimmed and fitting a new head gasket along with new Cambelt kit and auxbelt.
We hit a few snags but mainly little silly things like previous people over tightening and mangling some bolts on the coil pack. After removing the exhaust manifold, inlet etc etc.
Untitled by
JayS_182, on Flickr
Head came off and was then delivered to Ellesmere port engine centre for the skim. They are only open until 1 so I gave them ring as we were running a little behind so it went with the cams etc in and they sorted it all out and reseated our valves aswell.
Untitled by
JayS_182, on Flickr
While the head was away we checked the pistonheads and cleaned up the head ready for the new gasket.
Untitled by
JayS_182, on Flickr
We also decided to paint to few things.
Untitled by
JayS_182, on Flickr
New gasket on with a freshly painted block. Gasket was slightly thicker due to the skim, Cambelt pulley and tensioner also went on at this point.
Untitled by
JayS_182, on Flickr
Head came back, freshly painted aswell by the engine centre. Highly recommended these guys they stayed until 2 to get it done for us.
Untitled by
JayS_182, on Flickr
Next up tightening down the head. Stage 1 20nm, Stage 2 260degrees in the correct sequence for reference.
Untitled by
JayS_182, on Flickr
Rocker cover painted, resealed and back on. New plugs in, coil pack back on oil in aswell.
Untitled by
JayS_182, on Flickr
Untitled by
JayS_182, on Flickr
We also removed the oil cooler and have that a clean up looks much better.
Untitled by
JayS_182, on Flickr
Thats all I got from yesterday. Was a good day it's amazing what a lick of paint can do. The car a major oil leak before this so hopefully the new gasket, resealed camcovers and rocker cover should of sorted that.
Those pictures how far we got so we still need to put the new belt on time it up, alternator back on, new aux tensioner on, exhaust manifold, inlet, injectors, air filter etc etc.
I will be going out today at some point to do a little bit. Really happy with how yesterday went considering it was our first attempt at something like this.
