Warm missfire again
Iain C
So my cup has been off the road a year and a half partly because of a missfire when warm. Runs fine from cold. It will usually run for 25 min before the failure.
So far I've replaced
Leads
Coil pack
Plugs
Injectors
Engine sensor
O2 sensor
No errors showing
Anyone got amy ideas. Cos I'm out!
Ta
Yeah tdc sensor has been changed.
Coolant temp sensor hasn't been changed. I did think that actually. Maybe worth a change.
All Renault items or uprated.
My scanner isn't the best just a basic reader.
Ta
It will usually run for 25 min before the failurea
Sounds like a sensor failure in the engine compartment due to radiant heat from the engine block.
I would not bet on the coolant temperature sensor, as the car should reach running temperature in the coolant in less than 10 minutes.
25 minutes sounds more like a problem in the throttle body / TPS sensor receiving heat and getting a dysfunction.
But let us see how the new CTS affect the fault first...
if it was a vac leak it would be there all the time. get it plugged in with something decent and look at live data.
